Right time to start cracking ... anyone got any drawings/ideas for an engine stand to suit a ZX-12R engine? The mounting point dimensions would be enough then my friend and i can sort something out.
Do MNR not do an engine cradle??
yepp they definately do.
decided not to go down that route huh???
?what route? I need to build an engine stand so i can fiddle around with the engine, off the car.
[Edited on 2/1/07 by clutch_kick]
can you not just make one out of some steel,
measure the bottom holes gearbox side drill holes in them
same for front then you have 4 legs and brace the together and there you have it !
that is precisely what i want to do, however i do not have the engine in hand yet, so i thought somebody might have drawings or dimensions.
