1800 zetec/2.0L cams
ch1ll1 - 17/1/07 at 08:39 PM
hi all
fitting a 1.8 black top, will be putting 2.0l cams in it (from a black top)
it has solid buckets, will i need to change them with the 2litre ones of will it be ok or should i fit hydraulic tappets?
cheers paul
coozer - 17/1/07 at 09:22 PM
Normally just changing the cams is enough, but its up to you, whatever goes together easiest I would imagine.
Dusty - 17/1/07 at 10:35 PM
The blacktop won't do hydraulic buckets. When changing cams you should swop over the solid followers that go with the cams and keep them in order.
whitestu - 17/1/07 at 11:09 PM
Slightly off topic, what difference do the 2.0 cams make to power output on the 1.8?
Stu
