Fuel Line
The Doc - 20/1/07 at 03:48 PM
Anyone know if it matters whether an in-line fuel filter goes before or after (carb side) the pump? This is with a standard XFlow mechanical pump.
Also - how much flexible tube will the SVA man want to see between rigid pipe and engine. Obviously the engine is moving on its mounts. Should I put a small loop in it?
TA
Mike
Paul (Notts) - 20/1/07 at 04:33 PM
I have an inline filter between the tank and the pump, and then another in the engine bay before the carb.
Paul
rusty nuts - 20/1/07 at 05:11 PM
Apart from the strainer in the tank Ford didnt fit a fuel filter I.I.R.C.
