What method has anyone used to decide what injectors to go for?
I used the method in A. Bell's Tuned Induction book but that gave me four injectors @ 320cc/min for 160Bhp (80% duty cycle)... which seems a bit
much considering the same injectors seemed fine for wildly tuned Turbo Cossies....
Whenever injectors came up on fleebay I'd check with Stan Weiss' injector table but most gave around 200cc/min. Interestingly, for most of
the injectors I looked up the .42 BSFC bhp estimate (80% duty cycle) for s/c'd intercooled engines was exactly what I needed...
So who's right? It seems strange that Bell's method is so mathematical but seems to be wrong!!!
Anyone else got a equation for working out injector sizing or is it just "find injectors from a car with similar Bhp" time....?
The file I have attached shows calcs for varying fuel pressures and duty cycles and the effect they have on available BHP from injector sizes.
This shows that 270cc injectors at 3bar and 85% duty will give 184bhp. enough for me. For now!!!
Cheers mate, I'll have a play and see what it recommends for my boosted setup....
Still can't work out why the amount of fuel you need for a given BHP depends upon whether you've used an intercooler, whether you're NA
/ turbo etc etc... Never mind....
I am guessing it will because cooler air is more dense and therefore will require more fuel.
take a look in burton pwer catalouge - list the ford injector colours for bhp.
isn't bell in that case reffering to mechanical injectors perhaps?
if not what fuel presure is he using?
grtz Thomas
There may also be the issue of whether you are firing the injectors in batch or sequential as to what BHP they will service.
I used the method in A. Bell's Tuned Induction book but that gave me four injectors @ 320cc/min for 160Bhp (80% duty cycle)... which seems a bit much considering the same injectors seemed fine for wildly tuned Turbo Cossies....
Okay, cheers everyone, I'll put in some cheapo tintop injectors and see what I get!!! I thought it seemed to accurate to be true!
I had a set of injectors from a standard 2.0l blacktop zetec and a set from a VX which were supposed to be much better flow rates but when put on a flow bench at Emerald they flowed the same. and provided my 1.8 Zetec with 150 bhp
