I've got a chance of picking up a second hand 6 speed transaxle from a ST220 and wondered if the ratios would be any different to the bog
standard 5 speed.
Is there a list somewhere? I'm not sure where to start
Hi have found some info on these sites.
LINK 1 Gives infor for the focus st at the bottom.
LINK 2 . link to talk and info for the noble cars wich mentions and gives ratios for
the 6 speed they are using.
cheers matt
That's brilliant Matt - I should have known that the Noble GTO-3R uses the same box.
That confirms the gear ratios are a bit taller and would therefore suit my car much better.
Ta very much
