am I correct in assuming that this bellhousing will allow me to bolt a zetec engine to a t5 trans?
Which clutch/ flywheel/ pressureplate would I use?
I'm located in Canada so these parts aren't easy to come by, but there is a company the specialises in cosworths that can get me the
bellhousing I need.
Yes. These guys are in Vancouver. They can get any Cosworth or Pinto engine etc.
http://www.northamericancosworthspecialists.com/index.html
those would be the guys
and charge accordingly - but then it has to come from the UK. I thought about them, but went with an expensive toyota celica gts donor, of which I used only the engine, trans and wiring. I've now put $750 into the engine and trans - and that's not a rebuild!
