Air filter bike carbs
pinto - 4/3/07 at 06:59 PM
Hi all
want to get your thoughts on air filter on honda bike carbs
(engine pinto) not running any filter at moment ( do you really need to on normal fast road use ?)
1 Trying to work out size and shape of air box would you keep original trumpets on inside box (would rather not come out of bonnet)
2 would you take off black plastic cover which holds trumpets on or fix back plate to these (if you take these off you expose 3 little brass pipes one of which is blocked up and it seems to make it messy for air getting into carbs)
3 is it worth trying to duct cold air into air box or would a filter on end of box be much different
jacko - 4/3/07 at 07:32 PM
Hi have a look in my photo archives under zx9r carbs
i left my trumpets on and the plastic back on
PeterW - 4/3/07 at 07:37 PM
Jacko
Whats the tube you used for your carbs..?
Pete
jacko - 4/3/07 at 07:41 PM
Which tube? if you mean the blue tube it is silicant if you do a search you will find info on this
Jacko
pinto - 4/3/07 at 07:46 PM
thanks jacko looks good
[Edited on 4/3/07 by pinto]
Danozeman - 5/3/07 at 07:20 AM
Iv got an itg sausage on mine. I left the plastic backplate on with the trumpets, i found it easier to mount that way.
PeterW - 5/3/07 at 08:58 AM
Jacko
Sorry... meant the tube/pipe used for the manifold runners... Looks like 38mm thin wall..??
Pete
jacko - 5/3/07 at 05:08 PM
Hi the steel pipe is 40mm in side 1.5mm walls my carbs are 40mm zx9r carbs
Jacko
PeterW - 5/3/07 at 05:18 PM
Jacko
Looking at ally at the moment for mine
Pete
