I have one of these and am just in the process of fitting it to my gearbox and chassis. Trouble is, it is not symmetrical (front and back have
somewhat different profiles), and I'm not sure if it matters which way round it goes. It will fit on the gearbox either way.
Anyone know?
Thanks,
Shaun
ive just fitted one but i didnt notice a differance, dont think it will matter which way it is, which ever way lines up better with your mounting bracket
same here ^^^^ i bolted it to the bottom of the gear box lowered it in to the car marked out the hole positions than removed the engine and gear box and drilled the holes to fit.
