Hey Up
Which bike carbs would be best for a 2.0 litre Zetec engine?
cheers
Chris
Some people are using GSXR 600's or 750's.
R1 carbs are popular, but any from a 600 upwards,,
I'm using R1 carbs
Originally posted by chrisg
Hey Up
cheers
Chris
Hey Up
cheers
Chris
If you're going with megajolt for sparks, try and get a set of carbs with a TPS included, saves a bit of hassle later![]()
I've got Honda Blackbird ones on mine
(they have a TPS)
[Edited on 20/3/07 by givemethebighammer]
Will do Tony - Which ones have a TPS?
I "think" the later the bike, the more likely to have a TPS, something to do with
emmisions on later bikes ?
Thanks chaps.
so let's start a list(!)
Blackbird
and....
Chris
I have 1999 R1 carbs tied to a Boggs Brothers manifold. Had the head ported and planed .025 inches. Estimate the engine is doing around 170 hp.
Sounds sweet and awesome performance. I had to do some fiddling with the main and idle jets to get the right size (and you can buy these as std
sizes). Am very pleased
zx9 carbs e model have tps
GSXR 600 srad,
ZX6/7/9 later models
R1, although they fetch stupid money£150+
I'm using ZZR1100 carbs but they have no TPS. I may go for some zx9 carbs or try and fit the TPS off the Ford inlet manifold.
i got a set o blade carbs off flea bay with t.p.s.
£30 cheap as chips
r1 and black bird are more hi cost
[Edited on 21/3/07 by nige]
Thanks everybody - gives me a start!
Chris
Blade carbs seem a better price, and luckily bogg bros recomended them for ease of set up so thats what i did.
Chris, have a word with Malc at Yorkshire engines. In the last lot of TBs he had up for sale, there were a few sets of carbs available. He specialises in low-milage engines, he might have something ?
Anything over 38mm should be OK for a standard 2.0 Zetec.
I opted for 42mm TB's and think they are too big for a standard engine. Small throttle openings at low revs gives 100KPa so it makes it very
sensitive at low throttle.
They will be good once I tune up though!!
Most bike carbs come with TPS but if not they can be sourced from Maplins very cheaply.
Kawasaki zx9r ---e carbs have tps and are 41mm
Jacko
You know when you go on e-bay and you get carried away and bid on lots of stuff, just in case?
Well I appear to have bought some GSXR750 carbs. For £10.50.
Any TPS on those?
Chris
Edit I've solved this one myself - no TPS, what does Maplins list them as?
(It's not Throttle position sensors BTW!)
[Edited on 22/3/07 by chrisg]
