Can someone tell me where the Idle speed screw is on these carbs. Picture would be nice.
[Edited on 22/3/07 by grusks2]
Its the one in the bottom right of the picture in the link; It adjusts the idle for all 4 carbs.
Steve,
http://www.cartestsoftware.com/fz1/images/mikegtx45.jpg
[Edited on 22/3/07 by stevec]
Sorry steve my mistake, its the mixture screw that im after. Its running rich down low 1000 - 3000 rpm ( wet black plugs and spitting back through the
carbs)
It ticks over fine but soon as i try to bring the throttle up it pops and farts so to speak then tries to cut out.
I've been told that the low end of mixture is adjusted by a screw on each carb and above 3000 is by adjusting the needle clips.
Does that sound right at all.
I think these are they,
Steve,
Yup that looks like them. Wind them fully in (stop just after you feel harder resistance) then wind each out exactly the same amount - 2.5 to 3 turns.
Ill give them a go the weekend, they look slightly different carbs, i think Kawasaki and Yamaha have mikuni but slightly different. Finger crossed.
Cheers chaps
