i need a choke cable. Any recomendations? Ive seen the one on kitcar solutions but im not sure if it has the right end bit to go in bike carbs?????
Can you recomend any cheap air filter suppliers aswell?
Cheers ROb
Iv got a universal one on my bike carbs. U just need a push bike cable end on it. You can get removable nipples from most bike shops.
what is your nipple requirement?
I have some stainless steel bike gear cables going spare.
also how long?
I also just got a universal jobby... Didn't have the nipple to put on the end but put a bolt through the nipple hole and clamped the cable between two washers and tighten it up... Not much strain on a clutch cable after all....
I dont think you will need a nipple ,just clamp it up at the choke end.
i used the bonnet pull on the sierra column
My nipple requirement so to speak will need to be checked out. I presume its like the throttle bit and will take a bike brake cable type end.
thanks
rob
Mac#1 have cable and a selection of ends in stock. That is where im getting mine from when the time comes.
What about air filters? do you recomend bogg bros??
Ref filters - measure your centres and take a pic of the filter mounting face. then give Mark at Mac#1 a call. He had a pair of K&N's on the
shelf last week. I tried them but my spacing wasnt right so didnt buy them (im using ZZR1100 keihins).
HTH,
Darren.
