Which type of locking compound do I need to use on the six flywheel bolts on my 2.0L zetec ?
Secondly where do you get if from at a reasonable price.
Thirdly do I need to lock the clutch locating dowels and clutch basket (cover) mounting bolts as well ?
thanks
[Edited on 10/8/03 by givemethebighammer]
jus use thread lock for flywheel bolts,the others dont need any
Got a bottle of the blue stuff, I use for bolts I may need to undo at some time in the future. Can I use the same stuff ?. I have seen other types
which are red and green (apparently stronger and more permanent) ? Have seen talk of Loctite Green Loctite red ?? Don't really know the
difference between them all !!!
thanks
dunno bout colour but ive got stud lock bearing lock and thread lock,psose threadlock is the right stuff
Take a look at RS Components web site. They have a data sheet on line that gives all the info on the strengths and characteristics for the various types of Loctite products. They have a stupid URL something like rs.www.com
Try
http://www.rswww.com
cheers
Chris
