Cooling temp sender fitting
chockymonster - 17/7/07 at 11:34 AM
Gents,
I'm struggling to find a way to fit the temperature sensor into the cooling system on my car.
The sensor has a 1/8npt thread.
I've been looking for hose adaptors but I can't find one that goes small enough.
I want to plumb it in before the stat, which on my 2003 R1 install means into 19mm coolant pipes.
I seem to remember seeing a picture in an archive of a sender mounted into the metal outputs from the head on the R1, but that involved welding and I have no access to any welding gear.
Any suggestions?
lsdweb - 17/7/07 at 12:01 PM
You may be referring to my setup here under cooling
This was brazed but it's not a very elegant solution!
Regards
Wyn
gingerprince - 17/7/07 at 12:25 PM
paul
i've got a length of metal cooling pipe with a 1/8" npt boss (think it may be a caterham item). Not sure what diameter the pipe is but if it's any good you can have it. i'll measure it tonight.
sy
chockymonster - 17/7/07 at 01:49 PM
Cheers Sy.
BenB - 17/7/07 at 01:54 PM
Demon Thieves do them but they don't do a 19mm one (the closest is 16mm) and they're not cheap....
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=LMA090/B
rusty nuts - 17/7/07 at 05:40 PM
Had a similar problem fitting a coolant temperature sensor when I converted to injection. I ended up turning up a lump of ally to fit in line with a heater hose and fitted the sensor to that . Works fine.
chockymonster - 18/7/07 at 01:59 PM
Demon thieves and cheap in the same sentence, I never thought I'd see that
Koso make adaptors to do just this, I've just got an 18mm adaptor which is a snug fit for £12
