Hi. Has anyone any experience of the s2000 engine or the new civic type r? Looking for 240-250 bhp reliable and cheap!!
Drop Chris Mason a U2U. He is a member on this forum and has previously fitted an S2000 engine into an MK Indy
Phil
Here is his S2000 build diary.
[Edited on 25-7-07 by Hellfire]
s2000 correct rotation and rear wheel drive - great choice - ring dewsbury auto salvage and ask for z - he will be able to sort you out with a low mileage engine. iirc there are problems with using trpe r engine (front wheel drive?)
one thing tho...it wont be cheap!
get the audi turbo. might be cheaper!
i have a type r civic and it rocks had it 3 years and its a very nice car model ep3 fitted full scorpion pipe de cat air filter mods ecu mods and it
goes v well
o and its not cheap
IIRC the Civic type-r engines rotate the wrong way to make them rwd. putting it in a middy would work, get a 6-sped box as well.
Probably not locost tho, unless you can find one that's been rear ended.....
civic type-r spins the correct way and can be made rwd with correct bellhousing, has been done in westfields. uk spec 197bhp and jap spec 220bhp iirc.
I have seen them in use with hewland ftr transaxles eg juno racecars. For higher power supercharger is the easy option.
[Edited on 25/7/07 by ned]
Thanks. I've heard that the primaries are critical on the s2000, also I need the standard brain, wiring loom and ignition. Is that the case?
both engines can run on any after market brain
Ring John Beattie on 01952 727267.
He does a complete set up for these engines.
TB'S, ECU and dry sump.
Key to power is as I understand it, long inlet tracts and using the very odd looking standard exhaust manifold.
Power is 247 to 255 depending on day on his honest dyno. The really startling increase is at variable cam change over point where he found 55hp extra
over the Honda set-up.
One of the guys in the office has a elise running with a Type R engine and is using an Omex ECU. Apparently you can't tune the engine to its
best using an emerald. He did say that the Hondata ECU is the best to use.
[Edited on 26/7/07 by neilj37]
Originally posted by ned
civic type-r spins the correct way and can be made rwd with correct bellhousing, has been done in westfields. uk spec 197bhp and jap spec 220bhp iirc. I have seen them in use with hewland ftr transaxles eg juno racecars. For higher power supercharger is the easy option.
check out the westfield wscc site and do a search on honda or civic engine, loads of info on there...
s2000 engine.
most ecus can control it incl. vtec etc. i am going to use emerald. it;s a deep engine so lots of folks use dry sump (£1200-1500). good power approx.
250 bog standard. 350 with supercharger (£3,000-5000) Lump is pretty cheap. i paid 1650 (23,000 miles) plus 150 for loom. 700 for ecu. I have heard
that primaries are critical but i think this is just red (race engine design) propaganda. I am intending a matched 4 into 1 system. will let you know
how it compares to the standard s2k. Be careful with dif ratio. s2k runs a 4.1, and therefore i'm using one on a custom de dion setup.
bobster
Originally posted by tobym
Is this true, Hi I'm new by the way, and currently researching my options also, I read that they rotated the wrong way for RWD gearbox, have you any links to any info online?
Great, any suggestions on bellhousing's to mate it(the CTR engine) to a RWD gearbox, or suitable gearboxes,ta.
Checkout www.clockwisemotion.co.uk for some of the info you need..
Doesn't look like they're offering bellhousings/adapter kits yet.
Anyone have any experience in building their own bellhousings/adapter plates for other bellhousings/gearboxes?
If this is going into a Locost, note that these are very tall engines and will well give bonnet and/or ground clearance headaches.
I had my S2000 Rush mapped yesterday over at Gosfield airstrip. John Beattie (RED) came down and spent the day dialing the fuelling and timing in to
suit the Jenvey TB's and RaceTech ECU.
The end result was pretty impressive - calm, smooth and quiet on part throttle then pretty ballistic when booted.
(Sadly the 2nd S2000 Rush brought along couldnt be mapped as the ECU had gone pop due to a wiring problem.)
Once SVA is done, I'll take it up to Telford for a final mapping to smooth out any noticeable issues on the rollers.
J
