Oil filter question
albertz - 7/8/07 at 08:59 PM
I am in the latter stages of fitting a new 2.0 blacktop Zetec to my Locost. I am having real difficulty fitting the alternator, due to the size and positioning of the Griffin Power Systems inlet plenum.
I can get the LRA100 alternator in postion, but cannot get any tensioning rotation due to the proximity of the oil filter and the plenum chamber. Tonight, I bit the bullet and "persuaded" the oil filter to move down a wee bit, by generally deforming it on the end with a mallet.
I was wondering what implications this will have (bit late i know!!), is it just a loss of filtering capcity or will there be something more sinister? Bearing in mind the filter is probably good for 20K and that my annual mileage is less than 1K, will i get away with this, or should i buy a shorter filter as a precaution?
Any help appreciated, as always.
RichardK - 7/8/07 at 09:02 PM
remote oil filter, or thinner filter needed.
Job done
Rich
big_wasa - 7/8/07 at 09:09 PM
Renault 5 filter = £5-8
Fresh 2L black top ~£250
= No brainer
David Jenkins - 7/8/07 at 09:13 PM
I use a shorter Renault 4/5 filter on my x-flow - on the basis that I'll probably change the oil once a year anyway (2 to 3 thousand mile interval).
Fram PH2874
Halfords HOF266
This presumes that either will fit your motor, of course!
oadamo - 7/8/07 at 09:18 PM
= No brainer
pmsl
albertz - 7/8/07 at 09:20 PM
Thanks guys, your obviously right. I'll get a Renault 5 filter. Really i was just wondering if the dent at one corner (does a circle have corners?) would affect the performance significantly. - Whats the point in taking the chance eh!!
Somebody has to ask the stupid questions to make you lot sound clever answering them......
[Edited on 7/8/07 by albertz]
BenB - 7/8/07 at 09:30 PM
Some filters have a pop-valve on the end of the filter that gets activated if sludge collects in the filter. Works on the principle that if you don't change the filter its better for some crud to get into the engine than loose oil pressure.....
Potentially if you deform the end of the filter that could pop-out the valve causing you to loose all filtering and allowing pure crud to enter the oil passageways
Some filters don't have the valves though.....
[Edited on 7/8/07 by BenB]
