OK, mines not far out, but I am curious to see what jetting other people are using, in the hope that I might be able to sort mine out and get it a bit
closer.
I know I am running rich, but not sure by how much. Its not belching out black smoke but the plugs are sooting up.
Mines currently got:
55F2 idles - went from 50F9 being too rich by a mile and 50F2 being way too lean, and these ones seem a touch on the lean side, with a slight miss
under load at certain revs.
145 mains
180 air correctors
F16 emulsion tubes
36mm chokes
45 pump jets
Any help appreciated
mine was set up on a RR before i had the car but everything i have ever read has said it should be too rich!
To be quite honest. when i go the car one webber pair has 36mm venturis and one had 38s. I have changed them all to 36mm now
Starter Jets F985
Air corrector 180
Emulsion tube F16
Main jet 155
Idle jet 55F9
pump jets 45
Main venturi 36mm
aux venturi 4.5
I have bad misfire/stumble at about 2-2.5k rpm. Not sure if its main jets or idles/progression jets to blame? Some books seem to suggest idles but
they are already way too rich ticking over... My mains do seem a bit low compared to some, I have some 145s which I could try in the morning
Hi David
I had a quick look and found:
Chokes 36mm
Mains 140
Tubes F16
Idles 55F8
As I say it was a quick look - not a million miles from yours though
Mark
Flak - are you simply going on plu colour at idle to know if you are running rich or lean? I have heard that this can be very misleading. maybe you
could get it checked out with a lambda or something.
Do you get much spiting back? This, as you probably told me, is associated with it being too lean.
Do you get stumble at 2kish under load and no load?
As far as i understand the main jets only start to come in at around this point so it is more likely to be the idle jets which are causing the
problem. The main jets agree with everything i have read about this spec of pinto
Originally posted by cadebytiger
Flak - are you simply going on plu colour at idle to know if you are running rich or lean? I have heard that this can be very misleading. maybe you could get it checked out with a lambda or something.
As far as i understand the main jets only start to come in at around this point so it is more likely to be the idle jets which are causing the problem. The main jets agree with everything i have read about this spec of pinto
my other thought is that.. now let me try and explain this so everyone including myself understands. lol
if your idle jet is too small (lean) then maybe your butterfly is too far open or closed at idle (cannot work out in my head which it would be).
if it were too far closed off the progression drillings you would get a miss or hesitation.
maybe worth checking where you butterfly is in relation to your drillings. This can be done as i am sure you know but shining a torch down the chock
and taking the progression drilling cover off. you should be able to see the butterfly movement through the drillings.
like this
i have a nice article here.
just trying to find a way of getting it digitalish
sorry i have not been able to upload the document but the gist is that if the car stumbles under progression it can be because the idle jets are too
small.
Hope this helps and good luck
try some plug cuts to identify the area where the mixture may be wrong.a stumble around the rpm you mention may well be the transition from idle jets to mains
your mains don't look as it they are undersized. i know mine are larger but going by every thing i have read you should be very close. i think it is more likely to be the idles
Flak,
See post:
http://www.locostbuilders.co.uk/viewthread.php?tid=73557
I`ve just posted....
Hope it helps..
Maybe too late.....
LOL I`ve just used search,
you posted this very same info quite some time ago...
[Edited on 9/7/2007 by Angel Acevedo]
