just trying to work out where the pipes go on the thermostat housing, got the obvious ones but need some final help, does anyone have a diagram or any
good pictures of there set up?
any help would be apretiated
Looks a little different to mine. Mine doesn't have that hose coming off the top of the main outlet.
Under the main outlet there is another small pipe that needs to go to the bottom hose. Its a thermostat bypass for when the engine is cold and helps
towards a quick warm up.
The other outlet at the back goes to the heater.. if you have one, otherwise block it off.
what goes to the bottem of the overflow tank?
http://www.zetec-cat.co.uk/
http://www.toyne.org.uk/docs-cooling.html
Ford Zetec cooling diagram is explained on this site, was very helpful for me.
Rgds-JP
I used this to plumb in a Black Top. No problems so far...
http://www.emeng.gentlyhosting.co.uk/Cooling/Part1.htm
Tee it into the one from under the main outlet that connects to the bottom hose .
Paul.
thanks for the help, that should make it easier when the radiator arrives on wednesday
This should help - also check my pic archive for some pics of it actually on the car.
I followed the Toyne diagram - but instead of runing two pipes forward to the bottom ali pipe, because not using a heater, I've T peiced the
heater and bottom thermostat outlet together so there's some flow where the heater would be.
Not tried it yet though!
