Hi!
Recently bought a locost with live rear axle fitted - unfortunatly the previous owner towed it when it was empty of oil - the bearings are now
knackered. I have not a lcue about cars, but I'm GOING for it - and I'm hoping that the kind souls on here will be able to advise me when
I'm stuck!
Can anyone
a) advise what axle this is?
b) give me a rough ide of cost of replacement bearings?
c) give me a rough idea of time and difficulty involved in replacment of said bearings
This is going to be the first of loads of questions over the coming months (years?!?!?!) - so your help is greatly apprieciated guys.
rear axle
this might help!
That looks like an English axle to me.
yes looks english to me fitted to mk1 and 2 escorts anglias mk1 and 2 cortinas
chack part number KIT050:
here http://www.motoscope.co.uk/escort_mk1_2.htm#Rear_Suspension
under english axle
under english axle
Originally posted by Dangle_kt
Can anyone
English Axle, mk2 escort + others
Dunno but would not expect to be more than £ 20 per side
c) give me a rough idea of time and difficulty involved in replacment of said bearingsyou need to remove the half-shafts - has been discussed last week, then remove the collar on the 1/2 shafts - can be sawn or gound off followed by removal of bearings. The bearings should be pressed on but the hard bit is refitting the collars - you would need a huge press to fit them or heat them to red hot and whilst they are expanded, press them on. If that last part sounds quite daunting, then you can get half shafts from a couple of the parts people that advertise in Ford spotters Monthly. Oh, and make sure you have fitted the retaining flange before fitting the bearings !!!![]()
This is going to be the first of loads of questions over the coming months (years?!?!?!) - so your help is greatly apprieciated guys.![]()
Where about are you located?
If you are pulling the half shafts it might be a good idea to whip the diff out as well, it wouldn't like be towed with no oil in the axle.
Regards Davie
He would need to tow it an awful long way to knacker the bearings.
"ER you cant tow it with the shafts out anyway as the wheel hubs are part of the shaft, So no wheels no tow. "
NO SHIT........maybe read the first post again.
Could possibly be a brake binding problem.
I would jack up the rear wheels and spin them by hand, they shouldn't be tight if the handbrake is released, also try shaking the wheels to
feel for any play before removing the wheels and brake drums. With both drums removed the axles should feel nice and smooth without any horrible
noises.
Regards Davie
[Edited on 18/9/07 by daviep]
Originally posted by 02GF74
.....or heat them to red hot and whilst they are expanded, press them on.
^^^ re: heat.
Heat the collar not the bearings - they have a rubber seal.
I alsed about the tack weld, there was some discussion about this weakening the shafts but general consensus was that even so, very few popel
experinece this type of failure.
As ^^^ say, jack the rear wheels in turn ans turn them; test for play in bearings; maybe sticking some oil in the diff to oil the bearing may make the
problem go away?
could be dragging brake drums although as they heat up, then should become more free.
Nasty noise -- either the diff or the brakes
First thing to do is pull the drums off.
This is a good page of info - it's about back axle bearings on a Ford Crapi, but the only difference is the width...
LINKY
Just remember to drain out the oil before you start pulling half shafts... just don't ask how I found this out...
[Edited on 19/9/07 by David Jenkins]
LINKY
Just remember to drain out the oil before you start pulling half shafts... just don't ask how I found this out...![]()
