I've just fitted a crankcase breather outlet to my x-flow block.
No carbs
At the moment it's a jam-fit, so to speak, but should I use some liquid gasket stuff? There's no o-ring on the bit that sticks into the
block, so there's no seal as such.
Mind you, it won't be holding any pressure, 'cos the other end of the hose will go into the catch tank.
cheers,
all the ones i have ever fitted, a few! have always had an o-ring groove sure theres not one there? if not and its a tight fit i would leave well enough alone.
Just gave mine a light tap with a lead mallet, been in 12 months so far with no problems
That type is just a interference fit, wack it in with a soft hammer or block of wood and normal hammer and it will be fine.
Mines just tight fit in pinto and seems to work fine (well at least now ive stopped putting too much oil in!!!)
not to wory he's forgot the carbs and manafold, it aint going to run anyway
If your worried about it put some Loktight bearing fix on it before you knock it in.
adrian
bleu gasket sticky stuff around the thing and put it in. will be ok like that.
Btw that is by far the cleanest x-flow I've ever seen.
grtz Thomas
