I thought I'd got this problem fixed, but it looks like it's still happening...
My x-flow has a 4-branch exhaust manifold, and ever since I've had it I've had problems with getting a good seal on cylinder no. 4. The
main difficulty is that the port has only 2 nuts to hold it tight, and no matter how tight I do them up I still get a small amount of leakage. This
can be seen at the top of the photo below (and yes, I do know the photo's 45 degrees on the tilt!). There's only so much you can tighten up
the nuts without causing damage.
I've put a straight-edge along the mounting faces and they seem quite good - not perfect, but the 3 parts are on tubing so there is a certain
amount of bendiness.
I've lived with this for ages as it didn't make a huge amount of difference, but now I've fitted a wideband lambda sensor boss (which
is why it's off the engine) and I want to get rid of all air leaks.
Is it possible to get thicker gaskets? Or is there some goo that would seal the gap?
Exhaust assembly paste or silicon?
I don't want to use silicone as that would mess up the sensor...
I could use exhaust joining paste I suppose...
A light smear of exhaust paste either side of the gasket should cure that.
Place a thickness of cardboard under the side that touches.
Tighten the bolts, then heat the pipe in a narrow ring with that nice set of bottles you have.
Tighten bolts more and allow to cool.
Remove cardboard.
Paul G
p.s. Sorry
I've had the same problem with my crossflow. I think I finally solved it a couple of weeks ago. I used a light smear of (I think) hermatite red on both sides of the gasket. I also made a steady bracket from the bellhousing to stop the manifold from shaking. I used brass nuts done up quite tightly and then re-tightened once the engine was up to temperature. It seems to have worked so far.
i solved mine with exhaust paste and exhaust wrap over the top, worked a treat.
get it skimmed at an engineering company. i had to do it to my charade it was the only way to stop it.
adam
Copper washer might do the trick from a bec exhaust
I solved mine repeatedly blowing all the time by getting a set of copper gaskets from The 7
Workshop Not Losost though, about 4 years ago they were approx £30!
Apparently Ferriday Engineering also do copper gaskets...
Quick fix: buy 2 of those gaskets and put both in.
Permenant fix: take the manifold to an exhaust shop (or machine shop) and get the flange ground flat.
Hermetite Green I was told and worked OK.
Have used Red also.
HTH
Had the same problem myself on cylinders 2 and 3.
Looks like you have a large bore gasket (as I did ) Replace with standard size and it may fix it (it did for me)
Tighten the bolts, then heat the pipe in a narrow ring with that nice set of bottles you have.![]()
Originally posted by MikeRJ
Alternatively apply a file and liberal amounts of elbow grease to get the flange flat and at the correct angle to form a seal.
Beat myself up on this one for ages - try the smaller gasket first - easy and cheap
follow philm on the gasket differences, then if that's no good, use two gaskets.
I'm not a big fan of using goo on things that shouldn't need it.
On my XE I warped the flange when I welded it all up. There is one thin corner and it pulled up when welded.
I put a bead or two of weld on the sealing face then linished it all flat on a big belt linisher.
Trouble is, it's not an area that's higher than the rest - I think it's a low spot. Or the flange is twisted away from the mounting face a tiny bit. I'd have to file down all the other flanges to match!
I've had similar fun on my car with both my exhaust and inlet manifold. In both cases I used a friends 5 foot long belt sander. Meant for wood
working but the belt seemed to remove both ally and steel with no issue. Though at times I was a little concerned about small sparks catching on all
the saw dust surronding the machine. I couldn't mount the exhaust manifold in a milling machine as it came in one piece.
On the exhaust manifold I tried a multi-layer steel gasket and ended up using a single layer with a smear of silicone RTV as a temporary fix. I was
quite suprised to find the silicone still flexible when I took it apart to flatten. Especially as I used standard stuff and not the high temp variety.
