Hi all,
After a recent purchase, from a member (many thanks) see below
I fancy tuning it a bit, so has anyone got any xflow performance parts about they want to sell? steel rocker posts, roller rockers? uprated oil
pumps, steel pulleys?
naturally cash waiting. many thanks
New Engine
OT alert!
That rocker cover looks well funky. Apparently there is a market for exotic Ford rocker covers.some like then integral Piper fetch as much as 300
quid!
I have for sale an unused stage 3 head,
used manifolds, DCOE 40s, fixed vac advance dizzy with luminition, dry sump rocker cover, and a non-dry sump rocker cover (But your one is cooler
than mine.) and some other gubbings now i'm going zetec.
Originally posted by Fatgadget
OT alert!![]()
That rocker cover looks well funky. Apparently there is a market for exotic Ford rocker covers.some like then integral Piper fetch as much as 300 quid!![]()
I;ve got a stainless manifold for bike carbs if your interested?
Ray
I put a Piper BP285 cam on ebay on sunday, new but been stored a while with a very low reserve
Thats interesting amount of stuff!!
I suspect I'll be in touch in the near future.
Many thanks
Neil
Originally posted by Dave Ashurst
In the garage I've got some stuff. Some that I can't remember but some that I can:
Good bits:
2 or 3 used high pressure oil pumps (routinely replaced at each rebuild or upgrade but I kept the used ones because they work).
Lightweight steel flywheel and twin plate sintered racing clutch (that needs new plates) plates are ~£90 each before you make any rash decisions!
Pair of boxed, new, unused K&N 60mm filters for DCOE carbs.
a half decent modified big valve cylinder head off a hillclimb mallock. (that engine is currently being rebuilt with full race head so this one is surplus)
Stainless steel, used big bore 4-1 competition exhaust manifold (from a westfield SEi wide) - nice, and recently purchased, but it clashes with the chassis diagonal on my book locost (doh!). I'm too tired to start chopping anything. Hence - surplus I guess.
Sorry, I just parted with 4 DCOE 40 carbs 3 weeks ago.
Broken things:
a complete, plate-type LSD (english axle type) with broken cover plate - in bits in a plastic bucket.
The 4.1:1 cwp and diff casing that the lsd goes with. Actually that's not broken at all.
type 2 gt gearbox - in bits, in a plastic bucket & ripe for renovation (thrust bearing worn).
Drop me a line if you want to pop round and have a look, make me a fair offer etc.
I should probably put these and other stuff on ebay and tidy the garage.
rgds
Dave![]()
