pinto fuel plumbing diagrams?
Staple balls - 3/12/03 at 11:57 AM
has anyone got any info on where all the fuel lines and whatever need to go on a 1.6 pinto (with the bog standard weber carb)
cheers
alex
Staple balls - 3/12/03 at 10:45 PM
blah
what goes where on this piccy? (things that need a home are circled)
clicky piccy
JoelP - 3/12/03 at 11:18 PM
right then, the thing at the front of the engine is (you probably know) the fuel pump. The bottom is a feed from the tank, the top goes to the filter (left most hose) the spare tube in the *filter/swirl pot/ pressure regulator/whatever it is* is a return for excess fuel, goes back to the tank. HTH!
MK7 - 3/12/03 at 11:40 PM
Does mthis thread help?
http://www.locostbuilders.co.uk/viewthread.php?tid=4350&page=2
Russell
Staple balls - 4/12/03 at 03:26 AM
cheers both.
i thought that was how it should go, but wnated to be sure
