Non return fuel system
carl M - 30/4/13 at 07:27 AM
Hi,
Hopefully about to finish my build, would like some opinions on proposed fuel system (Zetec, GXSR TB's, MS III)
- High pressure pump below swirl pot at rear by tank
- Presure regultor plumbed in next to TB's on fuel feed line
- No return from fuel rail
- Return from pressure regulator back to tank
Using the above as it means I can use original GXSR fuel rail with adding a return feed.
Will it work
loggyboy - 30/4/13 at 07:31 AM
Not sure its the same on all systems but isnt the pressure regulator intended to be after the fuel rail?
dave_424 - 30/4/13 at 08:04 AM
That's definitley one way you can do it. One thing that a FPR on the end of the rail will do is help cool injectors. But since there isn't a return system when the TB's are on the bike then there is no need. What you want to do will work just fine
Dave
britishtrident - 30/4/13 at 08:33 AM
Over the last 12 years or so a lot of tin tops have put the regulator and its' return bleed inside the tank.
scudderfish - 30/4/13 at 11:18 AM
You may get problems with fuel vapourisation sat idling in traffic on a hot day. You may not though
omega 24 v6 - 30/4/13 at 11:44 AM
I have a gsxr pump mounted to a swirl pot in the base of the tank. Only one pipe to the fuel rail (Gsxr) and no external fpr ( as its done internally to the tank) fitted to a 2ltr c20xe vauxhall engine.
No evaporation or pressure problems at all.
Valtra - 3/5/13 at 08:42 PM
Dave
That's a relief that's how mine is getting set up
