engine age
cd.thomson - 24/6/10 at 09:33 AM
Vosa say that they're happy for me to use my vauxhall calibra haynes manual which states that the C20XE was discontinued prior to 1995 as proof for the lax emissions test.
The only problem is they want proof the engine is an xe from a calibra . Mr IVA suggested that I get a list of engine number ranges for the C20XE engine, is this a possibility?
Alternatively could a kind gentleman with access to invoice generating software please u2u me.
loggyboy - 24/6/10 at 09:48 AM
I have a vauxhall EPC which lists engine runs.
Can PDF the page relating to engine numbers etc.
cd.thomson - 24/6/10 at 09:52 AM
loggy, you're not otherwise known as M****** H******* are you?
eta: also that would be perfect.
cd (dot) thomson (at) gmail (dot) com
[Edited on 24/6/10 by cd.thomson]
loggyboy - 24/6/10 at 10:30 AM
I assume MH are someones initials? so no, not me!
silky16v - 24/6/10 at 10:45 AM
http://www.topbuzz.co.uk/
look under /information/technical guides/reading ecu fault codes
it lists all the cars that the c20xe was fitted too and the yr
cd.thomson - 24/6/10 at 10:48 AM
cheers mate, but what hes after is proof that the engine is what I say it is.
I think he wants a piece of paper that has an engine number range, which my engine falls into, matched to an engine type.
so for example if the engine number stamped on my engine is 15002350 he wants some documentation that says:
15002349-15009393 = C20XE
loggyboy - 2/7/10 at 10:13 PM
