wrigglypig
| posted on 11/11/08 at 07:15 PM |
drive shaft covers
I need some help, I took the chassis plate from my sierra donor to the local ford garage to order the metal cover sleeves that go over the drive shaft
cv's checked and double checked total of £2.81 each + vat total £13.25 all arrived looked fine. When I checked them they were too small in
diameter.In the meantime I had cut the old ones off. So I took them back to order the bigger ones hey are available and in stock, only prob is they
want £30.20 each £125 per set. I have told them it must be an admin error i.e. the decimal place in the wrong place i.e. £3.02p each any ideas????
Kev
eznfrank
| posted on 11/11/08 at 07:24 PM |
Have you tried ringing a few local motor factors?? What model is the donor? Some of the "better models may well be at a premium - be surprised
at that much of a difference though.
wrigglypig
| posted on 11/11/08 at 07:26 PM |
1.8 glx hatch h reg 1990
Paul (Notts)
| posted on 11/11/08 at 07:28 PM |
What size do you need?
did not realise there were different sizes.
Paul
wrigglypig
| posted on 11/11/08 at 07:35 PM |
They actually measure about 78mm dia. on the list at polar ford they show 2 47mm and 52mm these dias I think relate to shoulder where the boot fits
on. Its the 52mm ones I have ordered to try them but they had better sort the decimal point out!
Kev
| posted on 11/11/08 at 07:51 PM |
That's definately a clerical error!!!!
I'd try e-mailing some other place, in the past I've e-mailed
www.edwardsford.co.uk
and they've got everything I needed for me at cheap prices and sent everything via post....
MikeR
| posted on 11/11/08 at 07:53 PM |
i bought some a few weeks (2 months max) ago from ford for 10 pounds each(ish). That was steel 'cup' and rubber boot + grease.
are you sure you're not getting cosworth parts or something?
wrigglypig
| posted on 11/11/08 at 07:58 PM |
I m pleased its just not me that thinks its an error. The bits are for the right car dont suppose you know what size you got and or part numbers??
Kev
Thinking about it
| posted on 11/11/08 at 10:45 PM |
I have some infront of me.
83 mm where it fits on the drive shaft
60mm where the boot fits.
46mm long
If this is what you want i can give you the part number.
Cost about £14 for 4
wrigglypig
| posted on 12/11/08 at 05:32 PM |
mine are 78mm dia where they fit the joint about 45mm long and about 56mm where the boot fits over my ford dealer has been very "good"
stating they can do them at £28.00 each!!!!! they gave me part numbers of 6476495 or 89bg4k240ba any help would be appreciated
