r1_pete
| posted on 3/12/08 at 09:16 PM |
Throttle bodies & fuel injection help and advice needed.
I've decided to go for fuel injection, and junk the bike carb setup.
Have bought a set of GSXR750 bodies, removed the secondary butterflies.
Got a manifold flange and will be making up my on manifold.
Which injectors do people use in the gsxr bodies?
Which ECU should I go for, Emerald, megasquirt etc.....
Bit of a novice with DIY injection, so any help much appreciated.
1.8 blacktop zetec, with 130ps cams.
Thanks.
Pete.
[Edited on 3/12/08 by r1_pete]
austin man
| posted on 3/12/08 at 09:40 PM |
what problem ar you having with the carb set up ??.
Brother in law has injection and is using throttle bodoes on a 2 litre zetec protuces 165bhp using the emmerald ECU and set up by Dave Walker not
cheap. I think more people are going for megasquirt there appear to be a lot of maps available.
| posted on 3/12/08 at 09:41 PM |
Loads of people have had success with Megasquirt but I ended up fitting an Emerald ECU . I think if you are OK with electronics and spend a great deal
of time studying then Megasquirt would be OK . If you are like me them a ready made ECU may be a better bet. The Emerald is very straight forward to
fit with clear and easy to read instructions , comes with a map that should at least get you running , easy to make alterations to map and good back
up from Dave Walker. I managed to get pretty close with the fueling using the built in gas anyliser after fitting a lambda boss and a narrow band
sensor . Dave Walkers book on engine management is well worth a read and comes with a programme to play with which makes setting up a lot easier . Car
is far better than it was on carbs.
austin man
| posted on 3/12/08 at 09:43 PM |
sorry forgot to mention the brother in law is using the bicke carb as the throttle body, he has secured the damper to ensure only the butterfly is
operational
r1_pete
| posted on 3/12/08 at 09:48 PM |
Thanks guys, its not that I'm having problems really, its more the old case of upgrading before I've finished. The bike carb setup is
really neat in fact, boggs and zzr1100......
I'm ok with electronics, mainly old guitar amp circuits, but, pcb and soldering iron hold no fears.
Sebastian
| posted on 3/12/08 at 09:50 PM |
Hi Pete,
LocostBuilders » Forum » Engine & Transmission » Blue Injectors?
Look at my thread there is Stevebubs, i believe he has a set of GSXR750 TB's on a Zetec, just take a look in his archive for a few pictures.
Good Luck.
paulf
| posted on 3/12/08 at 09:54 PM |
The original injectors work fine, mine is a 2 litre running on gsxr 600 bodys and megasquirt.
If you are prepared to do a lot of reading up and spend time tuning etc then megasquirt is a good choice, if not then go for emerald or similiar that
is easier to get tuned by most rolling roads.
Paul.
austin man
| posted on 3/12/08 at 10:04 PM |
any recommendations for Bike carbs then as Im running twin 40's on a 1.8 zetec
beaver34
| posted on 3/12/08 at 10:09 PM |
i would use the management, that the person mapping it is best with, as its only as good as its told to be! i run mine on omex 600
| posted on 3/12/08 at 10:15 PM |
The advantage of Emerald is that you can hook it up to a LC1 wideband lambda and it's self teaching.... Okay you can fiddle a few sites for
optimum power later on but you'll get well into the ball park with a Emerald ECU and a LC1....
zetec
| posted on 3/12/08 at 10:46 PM |
Another vote for Emerald. I went to Emerald to get my injectors checked and was surprised by the place, a real engineering workshop, very helpful and
friendly. Suspect their success is due more to experience and knowledge rather than the b*llsh*t some tuning companys churn out.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
stevebubs
| posted on 4/12/08 at 09:09 AM |
Paul.
Agreed. However I respaced mine to DCOE spacing so a Jenvey fuel rail and standard car injectors bolted straight up with the help of some flat bar.
whitestu
| posted on 4/12/08 at 09:32 AM |
Can't a Megasquirt do this then?
Stu
Jenko
| posted on 4/12/08 at 09:53 AM |
Stu
Stu's correct....Megasquirt can do this, you enter the AFR you require in a table...Drive around hitting as many fuel sites as possible, and it
runs a conversion to give you the correct VE setting.
As mentioned, if your not afraid to get your hands dirty, then go megasquirt...
As for injectors, if you go for GSXR TB's (600 or 750), then the injectors they come with will be fine......For an 1800 zetec I would go with
GSXR 600 set up, and get the older version (K1, K2), so you can space them correctly.....
Emerald do great stuff, but it will cost more.
PJ.
paulf
| posted on 4/12/08 at 09:31 PM |
I also respaced mine but fabricated a fuel rail from some turned bosses to fit the injectors silver soldered to some 10mm bore steel tube.
Paul.
Paul.
