Tinks1
| posted on 26/1/09 at 01:31 PM |
Setting up
Any help appreciated I started my Indy for the first time this week end but I find that as it warms up the idle speed increases. I am running a 2.0l
pinto with an ECU and 32/34 weber. It sounds like it is "weazing" could this be a vacuum leak and would that give the symptons I am
seeing, and how do you detect where the leak is...? Thanks guys.
Mr Whippy
| posted on 26/1/09 at 01:36 PM |
I'd brush on some engine oil round the manifold joints and see if any areas become dry then that’s where the leak is. You'll also see some
blue smoke in the exhaust and that will confirm the fact. You'll hear loads of hissing on idle anyway with that carb, it just how they are. The
engine will always increase its idle speed when warm due to the engine being vastly more efficient than when cold. That’s why you set idle speed at
normal temperature.
[Edited on 26/1/09 by Mr Whippy]
| posted on 26/1/09 at 05:56 PM |
Too much messing about brushing oil . Spray suspect area with WD40 , engine speed will increase if leak is found . Quicker and cleaner than using oil.
FazerBob
| posted on 27/1/09 at 12:18 AM |
I'm with Rusty Nuts on this, WD40 (or similar) works a treat.
Bob
