Author: Subject: Changing pilot jet?
posted on 22/3/09 at 12:14 PM Reply With Quote
Changing pilot jet?
Anyone ever changed or drilled out the pilot jet on bike carbs?
My mixture screws are 3 turns atm and still running weak (16 afr)
Worried about unscrewing them until the spring pressure cant hold the screw against the vibrations.
So, its a 38 pilot jet, what does that mean? 0.38mm??
Is a 40 or 42 the next step, say with 1~2 turns out on the screw?
Paul TigerB6
posted on 22/3/09 at 12:21 PM Reply With Quote
The pilot air jet needs to be smaller rather than bigger in order to richen the mixture up doesnt it??
posted on 22/3/09 at 02:18 PM Reply With Quote
Hmm, the little brass jet next to the main jet.
Its got a tiny hole sitting in the fuel and a small emulsifier tube attached
Paul TigerB6
posted on 22/3/09 at 02:44 PM Reply With Quote
Ah gotcha - i know the bit you mean now sorry. Yeah going bigger should allow more fuel to flow but think you can safely wind out the pilot screw a bit further yet - some of the GSXR600's had the screw 3 1/2 turns out according to the manual (Mikuni carbs)
link to jet supplier anyway - i used to work around the corner from them
