Author: Subject: twin choke
goaty
posted on 30/3/09 at 07:40 PM Reply With Quote
twin choke
Hi,
Justa quick one, looking to put a pinto with the twin choke carb into my mates mk1 escort as a temp measure till the new engine is ready, but need to ask about the fuel return.
Is it a must to have one with the twin choke carb? or are they ok without??
just want to see if we gotta swap the tank as well.
thanks
mark chandler
posted on 30/3/09 at 08:05 PM Reply With Quote
Do not need a return as long as the pumps not overly powerful, just blank it off.
Paul TigerB6
posted on 30/3/09 at 08:06 PM Reply With Quote
Supply only required on all carbs as far as i know - its only some injection systems that have a return fuel line.
pewe
posted on 30/3/09 at 08:18 PM Reply With Quote
What they said ^^^ - as long as the fuel pump is standard Mk1 you will not need a return. If pump has been replaced with one supplying more pressure a return may be necessary.
Cheers, Pewe
goaty
posted on 31/3/09 at 06:40 AM Reply With Quote
cool, thanks.
Think he's got a solid state in it but shall check and see what happens.
thanks again
