Northy
| posted on 19/2/04 at 11:03 PM |
Webers don't "snap shut"
Hi all,
After playing about with the car tonight, I realised I had a high idle. After further investigation I found that the Webers are not "snaping
shut"
Any ideas what to try/look at?
Graham
Avoneer
| posted on 19/2/04 at 11:16 PM |
Hi G,
Don't bend that metal bracket. When they do snap shut, the bracket will compress the spring correctly!
Pat....
Viper
| posted on 19/2/04 at 11:23 PM |
Unhook the cable, now do they snap shut?
Tim
Avoneer
| posted on 20/2/04 at 12:00 AM |
Hi Tim,
No, that's his problem. Linkage off and middle connector off and neither carbs snaps shut on it's own.
Possible internal spring thing? I've got Dellortos so couldn't help. Maybe behind the metal service plate thing situated on the back of
each carb???
Pat...
Spyderman
| posted on 20/2/04 at 03:12 PM |
Shouldn't there be an external spring on the lever?
Spyderman
kingr
| posted on 20/2/04 at 03:40 PM |
Sounds to me like you just need to give it a liberal spraying with oil. Also try removing the accelerator cable, fully opening the carbs and releasing
them, the extra inertia can often allow it to close fully.
Kingr
ned
| posted on 20/2/04 at 04:24 PM |
i found mine had a load of crap in the tiny bearings on the butterfly spindle. its a nightmare to take the throttle spindle out I've been told,
I took the butterflies off the spindle in situ and rinsed it out with petrol/toothbrush i think. you will need to use loctite when putting the
butterflies back on with those tiny screws.
Ned.
beware, I've got yellow skin
Stu16v
| posted on 20/2/04 at 07:21 PM |
As Ned says.....
macspeedy
| posted on 20/2/04 at 07:27 PM |
don't know if it is wat ned said but make sure the nuts at either side of the carbs are not to tight, also add some grease to bearings under the
washers
[Edited on 20/2/04 by macspeedy]
Northy
| posted on 20/2/04 at 09:24 PM |
On stripping down the carbs I have found:
One of them just needed a clean and lube. Is much better now.
The other one has a stiff/sticking throttle shaft I guess thats either a bent shaft, or shafted bearings Neither of which I fancy doing
myself.
Anyone any ideas where I can send them for repair?
Graham
macspeedy
| posted on 21/2/04 at 10:10 AM |
http://www.carburetters.co.uk/
