Author: Subject: v8 to ford box
Justo
posted on 20/2/04 at 12:01 PM Reply With Quote
v8 to ford box
Anyone know where I would get a plate to attach a rover v8 to a ford box, even plas would do I can make it myself.
ned
posted on 20/2/04 at 12:04 PM Reply With Quote
you'd need an adapter bellhousing and you'd need to use either an uprated quaiife t9 box or most likely a cosworth t5 box. there are other boxes such as the rover or rangerover boxes available.
some company's sell the bellhousings, will be a few hundred quid. can't remember the companies but sure someone will be along shortly witht the details you need.
Ned.
beware, I've got yellow skin
mackie
posted on 20/2/04 at 12:35 PM Reply With Quote
You can hook one up to a T5 using the auto bellhousing from an SD1 and an adapter plate at the gearbox end I think, I believe this is quite a common method.
Either that or trying and find a good later-type LT77, not as good as the T5 but much stronger than a Type 9.
timf
posted on 20/2/04 at 12:51 PM Reply With Quote
http://www.v8tuner.co.uk/category.php?id=5
ChrisW
posted on 20/2/04 at 03:12 PM Reply With Quote
Luego have a V8 and T5 in their demonstrator Viento so they might be worth a call?
Chris
My gaff my rules
Justo
posted on 20/2/04 at 08:21 PM Reply With Quote
V8 g-box
Thanks for the info, I think I will use an lt77 box
tobyg
posted on 21/2/04 at 12:04 PM Reply With Quote
try ringing magnum motorsport they do bellhousings for rv8 to type 9 v6 gearbox if your not running over 200 bhp they should be ok! it costs £250 for bellhousing and about £75 for gearbox job done!
