Author: Subject: Rad temp switch [ pinto ]
jacko
posted on 25/4/09 at 04:01 PM Reply With Quote
Hi all what temp dose your rad fan cut in ? is it the same as the thermostat opens 84% ?
I have an ajustabel switch on my fan so can set it to what i like
my engine is a 2l pinto
Thanks Jacko
flak monkey
posted on 25/4/09 at 04:39 PM Reply With Quote
I would set it to cut in at around 90 deg. Thts when I manually turn mine on....will have to fit an auto switch when I go duratec.....
Sera
http://www.motosera.com
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/4/09 at 04:56 PM Reply With Quote
yup i think mine is 92 C
Marlon
posted on 25/4/09 at 05:55 PM Reply With Quote
About 92 also
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
craig1410
posted on 25/4/09 at 06:16 PM Reply With Quote
Mine cuts in at 92 and goes off at 87C. These figures are usually etched on some part of the switch. Be aware that some switches don't cut in until over 100C which in my view is way too high.
One thing I would suggest is that your cut-off point for the switch should still be above the thermostat fully open temperature. Otherwise the thermostat will be closed by the cooling effect of the radiator which means that water will no longer flow through the radiator. My thermostat is 74C for example so it is fully open at 87C when the fan stops.
Craig.
lotusmadandy
posted on 25/4/09 at 07:55 PM Reply With Quote
Mine cuts in at 92 and goes off at 85
britishtrident
posted on 27/4/09 at 06:44 AM Reply With Quote
It has to be higher than the thermostat, typically 92 to 95 (coolant boils at around 115 to 120 under pressure).
Dropout temperture is typically 5 degrees lower than cut in
[/I]
