Author: Subject: Cylinder honing
philw
posted on 27/4/09 at 12:42 PM Reply With Quote
Cylinder honing
The piston rings have gone on my car do i need to drop the crank to hone the bores or can i just cover it with something?
Must try harder
Mr Whippy
posted on 27/4/09 at 12:49 PM Reply With Quote
I once caught a dodgy landy garage vigorously honing away on a landy that was 'just sold' with the engine still in the car and the head just removed smoked like a chimney afterwards
Honing normally just removes the varnish and a tiny amount of metal so I'd not be overly concerned and would do as you say and just cover it well with rags
posted on 27/4/09 at 03:14 PM Reply With Quote
Honing beds the new rings into the cylinder wall, you should be alright to just wipe the crank after you've done the bores as you shouldn't be removing anything just score the glaze off.
philw
posted on 27/4/09 at 04:54 PM Reply With Quote
Cheers as i thought, i was hoping to go to Stoneleigh but i can't get a set of rings, would you f****** believe it a poxy vauxhall engine and none of the local motorfactors can get me a set
Not Happy!
[Edited on [1240851605R0=053030p: by philw]
Must try harder
posted on 27/4/09 at 07:59 PM Reply With Quote
Motor factors don't tend to stock piston rings . Engine reconditioners may be your best bet.
