bitsilly
| posted on 28/4/09 at 07:24 PM |
Diff ratio - basic question!
Choose any ratio diff, say 3.14:1
Which number is the input from the prop shaft?
blakep82
| posted on 28/4/09 at 07:27 PM |
3.14.
so for every 3.14 turns of the input, the wheels will turn 1
________________________
bitsilly
| posted on 28/4/09 at 07:38 PM |
so if a bike engine has low torque and revs higher, you would make it more useable by having higher input revs and lower output revs. So I would have
thought 3.14 ratio diff would demand the engine be torquey??
Wheras a big V8 has loads of torque and is much better at turning the wheels under load, so it requires a closer ratio, ie, it could handle
1.5:1??
So why is 3.14:1 the best for bike engines?
My head hurts.
blakep82
| posted on 28/4/09 at 07:42 PM |
erm, i think so, but i've never given it much though. my diff is from a 2 litre capri, engine is 2 litre vauxhall, and gearbox from a 2 litre
sierra. seems to make sense to keep it that way
mookaloid
| posted on 28/4/09 at 07:44 PM |
Your reasoning is good but remember that when in the bike, the large rear sprocket has a similar effect as the car diff.
I imagine that the lack of torque is somewhat compensated for by the relatively light weight of our cars
CaptainJosh
| posted on 28/4/09 at 07:49 PM |
Also there is usually a reduction on a bike box so it requires a longer gear.
bitsilly
| posted on 28/4/09 at 07:54 PM |
Ahhhh! The mist is clearing!
So if I can't find a 3.14:1 diff for a BEC then the only thing I sacrifice is top end speed (quite a lot)?
blakep82
| posted on 28/4/09 at 07:57 PM |
i think its the 3.14 thats generally used on becs. not really sure, but they tend to not be too cheap! look down on the main page, theres a thread
with 3.14 diff in the title.
Hellfire
| posted on 28/4/09 at 08:04 PM |
You don't necessarily want a 3.14 diff for a BEC. It depends on the engine you're using and it's specific gearing. For example, our
ZX12R has a 3.62 diff and is capable of 130mph. Not sure we'd want/need to go much faster but if we did, there's always the option of a
3.38 diff but I doubt we'd go as low as 3.14
Phil
SPYDER
| posted on 28/4/09 at 08:17 PM |
Top speed also depends on overall tyre diameter, don't forget.
You could be running 13" wheels, or 15" or17" with a huge variety of tyre sizes to choose.
Simply picking a suitable combination can help you to achieve the top speed you are aiming for.
Geoff.
Liam
| posted on 28/4/09 at 08:27 PM |
As above - it's horses for courses. Every installation will be different. Choosing your diff ratio is a function of your engine rpm, primary
reduction ratio (for a bike engine), gearbox ratios, tyre size and desired speed-in-gears. You really need to consider your individual combination of
components and desired driving characteristics. Plenty of online gear calculators you can use.
Generally, with everything else fixed, the lower the diff ratio (higher the number:1) the faster the acceleration/lower the top speed (assuming
it's gearing limited).
Liam
snapper
| posted on 28/4/09 at 08:29 PM |
Plus the bike has much bigger rear wheels
I eat to survive
I drink to forget
