Author: Subject: zetec exhaust manifold.
Dusty
posted on 20/5/09 at 10:06 AM Reply With Quote
Anyone know where I can get one made south of Bristol. Just fitted an ST170 engine and the exh ports look like they need 1.75" primaries. The old zetec manifold I have used for the last two years is 1.5" and leaves a step which will give impede flow.
There was reference to exhaust design theory on the board a while ago but I can't find it. Tied in primary and secondary lengths, diameters, engine HP and capacity etc. Anyone help by pointing the way?
[Edited on 20/5/09 by Dusty]
omega0684
posted on 20/5/09 at 10:10 AM Reply With Quote
go for as big a primary as you can get away with!
cd.thomson
posted on 20/5/09 at 10:20 AM Reply With Quote
Surely thats not the case is it? I realise you want low restriction but the scavenge effect of a 12" pipe is going to be negligible - sapping power?
I may be completely wrong, I'm just thinking of the induction side of things where bigger throttle bodies do not always give better performance above a certain size.
Craig
200mph
posted on 20/5/09 at 10:21 AM Reply With Quote
My four stroke tuning book has a formula and explanation - will look it out if you want.
Mark
If it isn't broke, fix it until it is
omega0684
posted on 20/5/09 at 10:25 AM Reply With Quote
yes your right there, having massive tb's or chokes in webers is pointless if you have a small exhaust,similarly a huge exhaust is useless in you have little induction, the aim is to get it all matched, inlet, valves and exhaust, so that the engine can breath as efficiently as possible.
MikeR
posted on 20/5/09 at 11:01 AM Reply With Quote
dave ashurst made the spreadsheet you're talking about.
It was based on the formulas from something or other.
smac
posted on 20/5/09 at 02:12 PM Reply With Quote
Does this mean you have a Zetec manifold to dispose of?
mr henderson
posted on 20/5/09 at 02:16 PM Reply With Quote
Having said all that, having too big an exhaust is nowhere near such a problem as too big on the induction side.
If the inlets are too big the gas speed is too low and cylinder filling, especially at lower rpm, is poor (low torque). But the exhaust gases come out under pressure, and gas speed is not so much of an issue
John
Dusty
posted on 20/5/09 at 08:04 PM Reply With Quote
Probably at some stage but its cr*p, 4:1 and probably too narrow for even a standard silvertop.
