jpindy3
| posted on 23/5/09 at 04:59 PM |
squeek from some where pinto
hi lads,i started my pinto up to day a there is a loud squeek coming from some where near where bell housing joins the engine,first of all i thort it
was the cam,them i took the cover off and its getting oil,so i carnt be that,or it could be that a jernal oil way is blocked,but im really not sure
where its coming from,i thort i might be the starter motor,took it off,its ok,the only other thing near all this that has oil going to it is the
crank,im a bit stuck really, i dont want to just run it and hope for the best,as it seems to me that somthing ant getting oil.
can anyone asist me
omega0684
| posted on 23/5/09 at 05:24 PM |
without being there to listen i think it will be difficult for someone else to diagnose it,
you say it sounds like its coming from the gearbox/engine faces. are all the bell housing bolts done up tightly? its not the sandwich plate rattling?
nitram38
| posted on 23/5/09 at 05:40 PM |
Dry clutch Thrust bearing or spigot bearing?
tomgregory2000
is it when you depress the clutch?
Could be release bearing, mine made this noise but its more of a screeeeeeeeeeeeeeeeeeeeech
jpindy3
| posted on 23/5/09 at 05:49 PM |
god knows where its coming from,
i have pressed the cluch in and its still there,and taken the fan belt off and ran it,still there,it sounds like a bird cheeping,it is ether the carbs
or the block,i dont really think it is the carbs,and if it is somthing dry in the block i would have thort it would have cased by now as i have been
running it on and off for about 15mins.
Danozeman
| posted on 23/5/09 at 06:08 PM |
Sounds like clutch release bearing to me if its at the back of the engine.. Does the noise change with revs?
Sandwich plate touching flywheel slightly?
Was the engine rebuilt?? A dry seal can squeal but very rare.
Dan
jpindy3
| posted on 23/5/09 at 06:21 PM |
alex has hopfully cracked it,split inlet gasket,if not i did run it without a air feilter so i could have sucked a blue tit in
omega0684
| posted on 23/5/09 at 06:22 PM |
and i take a bow, a thankyou! my status of 'Pinto Guru' is one step closer!
daniel mason
| posted on 24/5/09 at 12:00 AM |
well done guys. another happy customer!
jpindy3
| posted on 24/5/09 at 06:50 PM |
well done alex you were spot on.
changed the inlet gasket,new gasket maker,cleaned plugs as well,runs sweet.
thank you
