tomgregory2000
| posted on 26/5/09 at 07:58 AM |
Difference in air fliter backing plates
Im looking at getting a new air filter for my car.
It is a C20XE with twin 45 dhla's, now ive seen a backing plate that says its for a zetec.
Now my question is: the backing plate for the zetec should fit my vauxhall? No?
As far as i can see the carbs WILL be the same spacing so why are there different backing plates?
Tommy
snapper
| posted on 26/5/09 at 08:17 AM |
It's all down to the carb spacing, if your Vauxhall inlet manifold spaces the carbs differently to a Zetec one then the trumpets will be
close/further apart.
Pipercross have tec drawings of the spacings or you can get backplate blanks that you cut yourself
I eat to survive
I drink to forget
omega0684
| posted on 26/5/09 at 08:21 AM |
why don't you just get a blank back plate and cut your own holes?
Richard Quinn
| posted on 26/5/09 at 09:07 AM |
Tommy
The spacing between both chokes on the same carb will obviously remain the same but the spacing between the two carbs may be different.
big_wasa
| posted on 26/5/09 at 02:59 PM |
And even zetecs are differant from other zetecs depending on the make of manifold.
