Author: Subject: Propshaft Centre Bearing
GrumpyOne
posted on 7/6/09 at 05:40 AM Reply With Quote
Good Morning Everyone
I am hopefully going to use the propshaft from my Scorpio donor car, but it has a propshaft with a centre bearing. Do I keep the centre bearing and shorten each end or do I need to use a different propshaft from another car. Or when the propshaft gets shortened do I loose the bearing alltogether?
Colin
speedyxjs
posted on 7/6/09 at 07:28 AM Reply With Quote
Dont quote me on this but i think the centre bearing will absorb most of the propshaft vibrations.
ReMan
posted on 7/6/09 at 07:45 AM Reply With Quote
It depends on wat engine/gearbox and how far/straight it is to the axel
Unlikely you will need it imho, youll need a very short plain prop made/or yours cut up/modded
ReMan
GrumpyOne
posted on 7/6/09 at 10:22 AM Reply With Quote
Both answers are basically what I was thinking, on the one hand leaving it in might help cut down any vibration but on the other, by the time the engine gearbox is in, there will only be about three feet of propshaft left so is it really worth it?
What did everyone else do?
mgmiller
posted on 7/6/09 at 10:52 AM Reply With Quote
buy a new prop shaft - there about £120ish
blakep82
posted on 7/6/09 at 10:59 AM Reply With Quote
my prop was from dunning and fairbank, £130, can't whack it.
you should only need a single piece prop (don't quote me on that, not sure why they are sometimes used and sometimes not)
think you might find the scorpio one is too long anyway
________________________
GrumpyOne
posted on 7/6/09 at 11:46 AM Reply With Quote
I think the Scorpio one will be about the same length as the whole car
Thanks for your help, I am certainly leaning towards a one piece, much easier to build in I would think.
Colin
mgmiller
posted on 7/6/09 at 06:42 PM Reply With Quote
Got mine from bailey morris http://www.baileymorris.co.uk/
ReMan
posted on 7/6/09 at 06:55 PM Reply With Quote
The girly BEC's tend to huse them as the prop starts somewhere near the rad, so theyre quite handy
GrumpyOne
posted on 8/6/09 at 05:31 AM Reply With Quote
One little propshaft with no middle bearing it is.
Thanks all
