Michael
| posted on 24/6/09 at 09:33 PM |
Cupro Nickel
If a Cupro Nickel 8mm Tube is advertised on the net but says brake line can this be used as Fuel line??
Thanks - only ask as it appears quite cheapish but also its not a 25 meter roll.
miikae
| posted on 24/6/09 at 09:56 PM |
A quick search of Fedhillusa.com say yes to fuel line usage.
Linky
Mike
[Edited on 24-6-2009 by miikae]
If it can be done it i will be done .
| posted on 24/6/09 at 10:07 PM |
Did it say 8mm i.d. or o.d. It will most likely be too thin for fuel if it's brake line, it might work for a return pipe.
adithorp
| posted on 25/6/09 at 07:19 AM |
Yes, it'll be fine. The diameter is as big as used on tin-tops as well so don't worry about that either.
adrian
http://jpsc.org.uk/forum/
no. brake line will have thick wall thus restricting the of fuel flow, unelss you have 25 cc engine.
what is wrong with microbore domestic heating tube from B&Q?
iank
| posted on 25/6/09 at 07:39 AM |
Kunifer is a superior alloy.
Isn't pipe measured on ID and tube on OD?
Though best to confirm with the supplier.
Anonymous
Neville Jones
| posted on 25/6/09 at 08:50 AM |
We've been using 8mm and 10mm cupro-nickel 'brake' tube from Partco on boats for years, petrol and diesel, and never a problem. It
don't have the same problems as copper, doesn't 'work harden' and crack with vibrations.
You can flare it, and use proper fittings, instead of pushing rubber tube over the end and a hose clamp.
Go ahead and use it with confidence, and ignore the doom merchants.
Nev.
Michael
| posted on 25/6/09 at 08:23 PM |
Thanks for the replies will now search net for a supplier.
