Author: Subject: Zetec coil pack question
MK9R
posted on 19/8/09 at 10:00 AM Reply With Quote
I have a zetec 1.8 fitted in a 53 plate focus, the coil pack sits ontop of the engine to the right and is a single unit with the 4 leads coming out of it, is there one coil that supplies the power, or are there induvidual coils for each plug inside?? I ask because i may have a weak spark on cylinder 3. Any idea how to check???
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MikeRJ
posted on 19/8/09 at 10:03 AM Reply With Quote
There are two double ended coils. The Focus uses the "wasted spark" system e.g. Cylinders 1 & 4 spark at the same time, as do cylinders 2 & 3.
[Edited on 19/8/09 by MikeRJ]
MK9R
posted on 19/8/09 at 10:06 AM Reply With Quote
So if the coil was playing up i would have a weak spark on 2 and 3???
Cheers Austen
RGB car number 9
www.trackace.co.uk
ChrisW
posted on 19/8/09 at 10:39 AM Reply With Quote
Yes. If the spark is weak on only one cylinder only it's more likely to be the lead or the plug.
Also check that water hasn't got into the turret on the coil pack.
Chris
MK9R
posted on 19/8/09 at 10:46 AM Reply With Quote
Chris
All ok, new leads and plugs, looks like a knackered injector
Cheers Austen
RGB car number 9
www.trackace.co.uk
Danozeman
posted on 19/8/09 at 12:07 PM Reply With Quote
Id try and get a new coil to borrow and try. They are very common to fail on zetecs.
Dan
