Author: Subject: Oil leaking inside cambelt cover?
CraigJ
posted on 19/8/09 at 07:29 PM Reply With Quote
My sisters W reg astra 1.6 16v sxi has a large build up of oil inside the cambelt cover, what would be the most likely cause? the cam cover is not leaking neither is the end of the cams. the head gasket is fine. Oil pump maybe?
flak monkey
posted on 19/8/09 at 07:32 PM Reply With Quote
Front crank seal?
Sera
http://www.motosera.com
Ben_Copeland
If its not the stuff you said, then it's got to be the oil pump or crank....
Whatever it is, you'll have to replace the cambelt as the oil will have got into it !!!
[Edited on 19/8/09 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
r1_pete
posted on 19/8/09 at 07:35 PM Reply With Quote
Best way to find out where its comming from is to clean it up and then run the engine and see where its comming from. It can be any of the above and the belt will whip it up and spread it everywhere.
CraigJ
posted on 19/8/09 at 07:36 PM Reply With Quote
The cam belt needs to be replaced cos ive cut it off lol.
Am i right in saying the sump needs to come off to remove the oil pick up before i can remove the oil pump?
CraigJ
posted on 19/8/09 at 07:42 PM Reply With Quote
heres a pic, i have clean a lot of the oil off allready
