Richard Quinn
| posted on 24/8/09 at 02:21 PM |
Top hose / bottom hose
Most, if not all, cars that I have come across take hot water to the rad via the "top hose" and cooled water back to the water pump via
the "bottom hose". Why is it this way round and why not the other? Maybe it is in some cars but I haven't seen any as yet.
tomgregory2000
| posted on 24/8/09 at 02:24 PM |
heat rises
Project7
| posted on 24/8/09 at 02:26 PM |
Because physics says that the cooler water will be at the bottom.
omega0684
| posted on 24/8/09 at 02:37 PM |
and you would have to pump the water upwards against gravity, using up more of the engines created engine = less horses at the wheels!
MikeRJ
| posted on 24/8/09 at 02:56 PM |
In a closed system pressure at the pump inlet will only be a little lower than at it's outlet, so gravity won't have much effect. Just
like a central heating pump, it would never be able to pump water up one or two floors unless it had the pressure of the returning water at it's
inlet.
The reason is that water will naturally circulate upwards through the engine and downwards through the radiator due to the thermosyphon effect; hot
water has a lower density than cold water so will rise to the top of a system if allowed to do so. Similarly the water being cooled in the radiator
falls to the bottom as it's density increases. This gives you a natural flow of water which the pump assists.
It could be connected the other way around, but the pump would be fighting the thermosyphon action
| posted on 24/8/09 at 03:10 PM |
Some early engines didn't have pumps at all and just relied on thermosiphon..... (as expertly described above!!).
Mark Allanson
| posted on 24/8/09 at 03:24 PM |
The main reason is that if the coolant level falls a little, the top hose would only suck air.
britishtrident
| posted on 24/8/09 at 06:04 PM |
A very very few recent engines have tried to do it the other way round for emission control and fuel efficiency reasons --- here be dragons.
[/I]
