franky
| posted on 22/9/09 at 12:03 PM |
fitting rubber hose to firtree connections....
I've just about broken my wrist trying to do this.... is there a tried and tested solution to make it easier? I've got the rubber
aeroquip hose that i'm trying to mount onto firtree connections(oil).
can I heat the hose up slightly? or use a type of 'lube'
I was thinking about using oil but i'm not too sure if its a good idea?
I've tried searching but can't find anything!
blakep82
| posted on 22/9/09 at 12:05 PM |
if they are oil line fittings, i can't see a problem using a drop of oil to lube it up
________________________
flak monkey
| posted on 22/9/09 at 12:07 PM |
Yep, dab of oil will do the trick.
Sera
http://www.motosera.com
franky
| posted on 22/9/09 at 12:19 PM |
tried a drop of oil... they're so bloody stiff
| posted on 22/9/09 at 12:29 PM |
they're not metal pipe per chance
stick the ends in hot water, shoulkd soften them.
are they the correct size? there are oil hoses that are designed to be fitted withoiut clips onto the fir tree ends but I don't recall them
being that tight, perhaps you are quite weedy.
franky
| posted on 22/9/09 at 12:32 PM |
obviously rubber!
As for being weedy... you may well just be right I'm more worried that if I try too hard I might alter the direction the world spins.
miikae
| posted on 22/9/09 at 01:03 PM |
A dab of oil and 3 plus shreaded wheat should do the trick after dipping the pipe in the warm milk first.
Mike
If it can be done it i will be done .
blakep82
| posted on 22/9/09 at 01:04 PM |
quote: Originally posted by franky
obviously rubber!
ah, cool, i'd like to see the water spin the opposite direction in the skin plug
franky
| posted on 22/9/09 at 03:01 PM |
did anyone notice a gravitational shift?
Putting the hose in hot water and a dab of oil along with lots of manly grunts has done the trick.
Oil system now 70% plumbed in. Just got to decide where to mount the accusump and wait for an oil cooler to arrive.
steve m
| posted on 22/9/09 at 05:54 PM |
"As for being weedy... you may well just be right I'm more worried that if I try too hard I might alter the direction the world
spins."
i did laugh
