Author: Subject: duratec main bolts
goaty
posted on 16/10/09 at 12:22 PM Reply With Quote
duratec main bolts
Hi,
just need to check if these need replacing when taken apart??
i have seen ARP do a stud kit for them...worth doing or should bolts be up to the job??
thanks
Mr Whippy
posted on 16/10/09 at 12:55 PM Reply With Quote
Tbh I’m surprised your asking as surely your using some sort of manual to get the torque settings and usually they also say if the bolts are one time use only.
You also don’t say what use the engines going to get, road, race, scream the nuts off it rally??
posted on 16/10/09 at 01:21 PM Reply With Quote
And the winner of todays most helpful reply is... NOT MR WHIPPY!
Mr Whippy
posted on 16/10/09 at 02:23 PM Reply With Quote
All I’m asking is if he’s using a manual as like I said they usually say the bolts are one use, plus he’s asking if he should change to a stud kit instead but why would he think that the original bolts would not be enough that he has to use studs? I thought he might be really tuning the engine?
[Edited on 16/10/09 by Mr Whippy]
Stuart_B
posted on 16/10/09 at 03:12 PM Reply With Quote
hi, if you are taklking about the headbolts, yes they are stecth bolts, so once they have been taken out they need new ones, as i have my set here ready to reassmbley my engine
hth
stuart
goaty
posted on 16/10/09 at 03:30 PM Reply With Quote
Not the head bolts as i would have typed head bolts...lol.
Main bolts (crank cradle), i am guessing they are purely by the way they came out.
I am asking about the ARP version as it will be superchargered with over 300bhp so if i need to buy new ones which by the looks i do thne i may aswell go ARP as i am using ARP head stud kit.
As for a manual Mr whippy, only need one to put it back together, not to take apart
lol to scootz, it was helpful
goaty
posted on 16/10/09 at 03:55 PM Reply With Quote
or will std main bolts be upto it??? i need to order something as the bottom end is being taken to scholar next friday sio need all the bits for then.
Not sure what i've forgotten yet but sure it will be something...
snapper
posted on 16/10/09 at 06:43 PM Reply With Quote
If you are spending lots on the engine then ARP bolts are a safe bet, however if you are taking it to Scholar then call them and ask.........
I eat to survive
I drink to forget
goaty
posted on 16/10/09 at 07:09 PM Reply With Quote
got to wait till monday now, have emailed asking if they can supply them. If they do then makes life easier, if not i shall get some on order.
Does anyone know if 2.3 and 2.0's use the same main bolts and head bolts?? or is the a diff. I imagine there would be on the head ones, not sure about main.....
cheers
