Author: Subject: Does an engine need to be level?
speedyxjs
posted on 28/10/09 at 02:54 PM Reply With Quote
My engine is sitting level atm but the sump is hanging about 2 1/2" below the chassis.
Im thinking about getting some plates made to raise the engine a bit but i cant raise the gearbox due to lack of room.
Will this cause any problems?
cd.thomson
posted on 28/10/09 at 03:02 PM Reply With Quote
i suspect people will say yes BUT the natural environment for my XE is at right angles to the car and cantered over at 7 degrees.
XE god Yukspeed was pretty definite I should fit it upright in my car though so it cant make a huge difference.
[Edited on 28/10/09 by cd.thomson]
Craig
matt_claydon
posted on 28/10/09 at 03:09 PM Reply With Quote
It's fine to tilt it side to side by rotating on the crankshaft axis, but you shouldn't tip it forward and back as your diff input flange and gearbox output flange will be no longer parallel. This causes cyclic speed fluctuations in the propshaft and therefore vibration and fatigue.
belgian2b
posted on 28/10/09 at 03:10 PM Reply With Quote
Hello,
position of the engine itself is not a problem.
you have to watch out for oil level in your sump and about oil suction system position in your sump.
Gerardo
speedyxjs
posted on 28/10/09 at 03:29 PM Reply With Quote
Its not side to side, its lifting the front up
matt_claydon
posted on 28/10/09 at 04:22 PM Reply With Quote
Most people get away with very small misalignments, but it's hard to say how much is acceptable.
[Edited on 28/10/09 by matt_claydon]
Ivan
posted on 28/10/09 at 04:28 PM Reply With Quote
I agree with this, however there are two ways around this, you could use CV joints instead of universal joints on the propshaft or tilt your diff to match.
In a mates Cobra the CV jointed propshaft made for a super smooth ride and withstood 12 second 1/4 mile runs and is still working ten years on.
MikeRJ
posted on 28/10/09 at 05:55 PM Reply With Quote
You'd have to have CV boots capable of withstanding the much higher speeds of a propshaft though, and CV joints do have a greater power loss than UJs.
snapper
posted on 28/10/09 at 06:12 PM Reply With Quote
The Pinto sits front end up in the Sierra only car it sits flat in is a Seven
I eat to survive
I drink to forget
matt_claydon
posted on 28/10/09 at 08:31 PM Reply With Quote
I suspect the diff sits front-end up to suit, otherwise it's pretty poor design.
RAYLEE29
posted on 28/10/09 at 08:52 PM Reply With Quote
The really correct way is to have it at the same attitude as in the donor, having said that most inlne installations have the engine sloping down at the back and as for all this propshaft stuff take a look at a transit prop
matt_claydon
posted on 28/10/09 at 10:51 PM Reply With Quote
Parallel input and output flanges are not the only way to eliminate speed fluctuation, but it's the simplest for most people to implement. I'm not familiar with the Transit arrangement but I suspect it either uses a double-Cardan or CV joint at one end or uses the not-so-common 'broken back' shaft arrangement.
If you don't understand the input/output speed fluctuation of a Cardan joint, the problems it causes and the ways it is eliminated, read some of these:
http://www.4xshaft.com/driveline101.html
http://en.wikipedia.org/wiki/Universal_joint
http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
http://www.custompistols.com/cars/articles/ts_ujoints.htm
Propshafts are one of the most dangerous and yet most misunderstood parts on amateur-built cars. It's no coincidence that we read about such a relatively high number of prop failures on here and yet it's almost unheard of on production cars.
norfolkluego
posted on 29/10/09 at 09:34 PM Reply With Quote
How do you(or what's the best way to) check they're parallel?
Bluemoon
posted on 31/10/09 at 05:34 PM Reply With Quote
I think I used an adjustable spirit level to check. I measured the angle between the diff flange and then engine on a machined horizontal surface (i.e top of block, top of head etc), i.e this should be 90 degree between flange and engine top.. I probably used other methods two, (can't remember what!).. From memory the alignment should be to 1 degree or better, this might not be correct though..
I should really re-check this soon, as the engine/gearbox can drop at an angle and require slight adjustments after it settles.
IMHO worth looking at this properly other wise you could have real trouble, also you might get away with it but it's not worth the risk (snapped prop)...
Dan
Bluemoon
posted on 31/10/09 at 08:34 PM Reply With Quote
^^ Just remembered the above is not the whole story you also need to check that the engine is straight (i.e. engine crank/gear box 90 degree to the diff flange)..
Dan
