Author: Subject: 1.6 starter motor
lewis
posted on 31/10/09 at 10:28 AM Reply With Quote
1.6 starter motor
hi all, i have a 1.6l starter motor from my 1989 sapphire donor car could i use this on my blacktop 2.0l/type 9/zetec 1.8 flywheel? or do i need the 707. thanks.
also is a AES7107 the same as a 707?
[Edited on 31/10/09 by lewis]
big_wasa
posted on 31/10/09 at 11:37 AM Reply With Quote
Was the saf' pinto or cvh. The cvh should fit but the pinto one probaly will not.
The pinion interfeared with the back of the flywheel with a pinto one I tried.
lewis
posted on 31/10/09 at 11:44 AM Reply With Quote
i think it was a pinto? it was on carbs if that helps
austin man
posted on 31/10/09 at 04:16 PM Reply With Quote
Nope got to be the 1.8 cvh or 2l DOHC starter motor for the silvertop
lotusmadandy
posted on 31/10/09 at 05:38 PM Reply With Quote
You can use the pinto starter on a zetec.
I have one fitted on my silvertop,you just need to put a 14mm spacer between the starter and bellhousing.I used m10
penny washers and welded them together.Have had no problems so far.
