stevegough
posted on 17/11/09 at 09:44 AM |
shortening the sump c20xe
Ok, Im going to shorten the sump. -
I've got the original ally one and a steel one (from an 8 valve - obtained from this site).
The ally one has an oil level sensor which has to be removed - no room for it.
The idea is that it is easier to cut and weld the steel one than the ally - I'm not much of a welder - but I know a guy who is!
I have had a suggestion to screw the top of the sump to a piece of worktop to prevent distortion - sounds like a good idea.
OK.....
Questions for you knowledgeable locost guys.............
1... what do I do about the oil level sensor - just short the contacts? (I'm using standard ecu / injector set up).
2.... what sort of baffling do I need to add?
3.... what about the dipstick - no, I don't mean me, I mean the original one!
Any other guidance / info will be most welcome.
Thanks in advance, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
cd.thomson
| posted on 17/11/09 at 09:55 AM |
Hi Steve this is mine:
1. Not sure what you do about the oil level sensor on the ecu, I just took mine out.
2. you can see the baffling Trev D added above, the side "pods" are also drilled through rather than being open
3. The dipstick doesnt measure the entire depth of the sump, so if you add back the same volume to the sides then the original dipstick should still
be fine for checking the level.
to add:
you'll need to relocate the sump plug of course and you do need to add back the volume you take away else you'll get all sorts of
problems
finally, the last picture just shows that you also have to shorten the oil pickup pipe (just cut a chunk out then braze it back together) as it is
designed to take oil from the bottom of the sump, which is now higher than it was before.
hope this makes sense.
Craig
omega 24 v6
| posted on 17/11/09 at 12:29 PM |
Sorry for the thread hijack but does your sump mods work CD thompson??
I have modded mines twice but still have oil surge ( lack of pressure) under heavy/prolonged breaking.
I'll post some pics later if I can find them.
cd.thomson
| posted on 17/11/09 at 12:32 PM |
not started it yet, but I'll let you know shortly after christmas!
Craig
Ben_Copeland
| posted on 17/11/09 at 05:01 PM |
The oil level sensor was never connected to the ecu in the first place. so just throw it away!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
stevepj
| posted on 17/11/09 at 05:02 PM |
The steel sump cut to 110mm will be level with the bottom of the type 9 box and give you just under 4 litres capacity inc filter to max on the
standard dipstick. You can add a wing on the side to get the capacity back up to 4.5 litres, but do not overfill as this will lead to the crank
aerating the oil.
Use 3mm steel plate for the new bottom, mine is in a Robin Hood 2B, bigger than most 7s with 75mm clearance under the sump and it has a few battle
scars from hiiting the road etc, I think an alloy one would have cracked lookin at some of the scars on the steel
stevegough
| posted on 21/11/09 at 04:33 PM |
thanks to you guys for all the helpful replies, I'll start hacking next week.
Regards, Steve.
Luego Locost C20XE.
