Author: Subject: Arrrrgh, ali bellhousing!
posted on 18/11/09 at 03:13 PM Reply With Quote
Cold out there today mind you... I'm changing the cast iron type 9 bellhousing for an RS2000 ali job, saving 6kg.
New release arm arrived this morning and cracking the bolts that hold the housing to the gearbox I see they are 30mm M12 x 1.5 and too short for the RS one which has thicker flanges....
So, where can I go get some 35mm M12x1.5 bolts? Local fastener place has minimum order of £10+vat and I only need 4 off not £11.50 worth...
Its never simple is it??
mookaloid
posted on 18/11/09 at 03:38 PM Reply With Quote
you'll also gain some of the weight back you've just lost with the longer bolts
dhutch
posted on 18/11/09 at 03:48 PM Reply With Quote
Lol!
Cant help you, unless geting them from my bolt place (min order of 20p being record so far) and posting them snail mail helps.
Daniel
jimgiblett
posted on 18/11/09 at 03:56 PM Reply With Quote
I would suggest you try an a different motor factors.
Cromwell tools have always helped me out in the past when I wanted a small quantity of non standard bolts.
http://www.cromwell.co.uk
Give them a call.
- Jim
deezee
posted on 18/11/09 at 04:01 PM Reply With Quote
I could send some out if you want them?
iank
posted on 18/11/09 at 04:20 PM Reply With Quote
Give them a call.
- Jim
There's a Cromwell branch on the Team Valley. Had a few bits from them, always very helpful in my experience (assuming they stock those bolts)
Anonymous
jambojeef
posted on 18/11/09 at 07:46 PM Reply With Quote
Its the fasteners place on the the team valley that you want!
Anixter (as was INFAST) - fromt he A1 southbound take the team valley turn - at the roundabout turn right and immediately take the first left.
Anixter are on the corner - dead helpful blokes and they have huge stocks of all kinds of bolts and nuts, washers thread lock - all that kinda stuff. Must have spent a small fortune there over the years but was worth it.
Geoff
kj
posted on 19/11/09 at 08:19 AM Reply With Quote
2 place near armstrong industrial estate Washington just up where the old b&q was, realy helpfull the one in the far corner and just normally asks for a £1 for the coffe machine when i got my 4 prop shaft bolts.
Also a place near Haverton hill industrial estate, can't remember the names sorry.
