omega0684
| posted on 19/1/10 at 06:02 PM |
Gearbox Ratio's
How do i know what gearbox ratio's i need?
Theshed
| posted on 19/1/10 at 06:12 PM |
Quaife have a free gear ratio calculator on their website. You will need to gusetimate your peak power and peak torque rpm and decide on the ideal
shift point/points.
| posted on 19/1/10 at 07:03 PM |
If your using a standard type 9 then first gear is way too low. Have a look at the BGH website
Xtreme Kermit
| posted on 19/1/10 at 08:41 PM |
Gearcalc is what you are after...
http://locost7.info/gearcalc.php
It has a whole range of type 9 ratios built in.
Dave Ashurst
| posted on 19/1/10 at 10:57 PM |
No substitute for the others above, but you could play with this perhaps. (you've seen it before)
Note :
5th gear needs reinstating if you want to plot that.
It doesn't model the start properly so ignore the 0-60 time
Let me know if you need it explaining.
best
D
Dave Ashurst
| posted on 19/1/10 at 11:02 PM |
...also saved in MSExcel 1997-2003 format (not sure this one works ok)
