barrie sharp
| posted on 24/1/10 at 01:05 PM |
cluch stuck
Hi has anyone got any tips for freeing up a clutch (type 9 to 1300 crossflow) i have just tried to drive the car for the first time in 3 months and
cannot get it in gear, any tips?
thanks
[Edited on 24/1/10 by barrie sharp]
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
SeaBass
| posted on 24/1/10 at 01:38 PM |
mmm. You should be able to get it into gear by rocking it backwards and forwards. Once in gear (3rd or 4th) depress the clutch and try to start it.
This should free it off. Make sure nothing is in front of the car.
JC
Miks15
| posted on 24/1/10 at 02:43 PM |
has the cable slipped or something? is the much pressure on the pedal?
MikeRJ
| posted on 24/1/10 at 02:56 PM |
Most likely the friction plate is simply stuck onto the flywheel or pressure plate, quite a common problem on cars left for a while without being
driven, especialy in wet weather.
If starting it in gear with foot on clutch doesn't fix it, driving it around for a while with your foot right down on the clutch and giving it
some welly will usualy do the trick.
[Edited on 24/1/10 by MikeRJ]
| posted on 24/1/10 at 05:00 PM |
Jack up the back of the car, spin up the engine, get the back wheels spinning round then (with your left foot hard on the clutch) slam on the brakes.
That should sort it out one way or the other
barrie sharp
posted on 25/1/10 at 07:31 AM |
Thanks for the replys. I tried starting it in gear a few times and it come free. thanks again
